Use a cat 5 crossover cable. In a direct configuration a non corssover will not work. What are your network settings? Which software version is 3PC and which version does the DP have?
hi i launch a new show. and aply hardreset to dp and works fine. but i cannot shut down the hog pc..not respond to shut down.
the problem is in a old show, in network settings detect the dp 2000, but in the screen of the dp appear iniatilazing network.and not is working the dp 2000 i try put the dp in 2. and nothing.
