Problems with LiteCraft PowerBar4
i recently updatet my iPC to 3.0.3 and due testing i got the following effect:
I had several LED-bars (Litecraft PowerBar4) in Mode4, so each bar has 16 channels. One bar consists of 4 segments each having 4 channels (red, green, blue and white). To work with it i used the "RGB + Amber" fixture and patched 4 fixtures for one bar. So i can use "I Red, I Blue, I Green and I Amber" for creating colors and also i can use Intensity and CMY.
By using the "I Amber" the LED-bars turn into white and if i press the clear button, the programmer and also the output clears, but the LED-bar still remains white. If i touch the "I Amber" wheel and set the value to 0% the white leds go off...
I created a new fixture from the existing "RGB + Amber" and edited it.
Original fixture:
channel 1 - cyan - variable - 255 > 0 - 0 > 100%
channel 1 - i red - intensity - 0 > 255 - 0 > 100%
channel 2 - magenta - variable - 255 > 0 - 0 > 100%
channel 2 - i green - intensity - 0 > 255 - 0 > 100%
channel 3 - yellow - variable - 255 > 0 - 0 > 100%
channel 3 - i blue - intensity - 0 > 255 - 0 > 100%
channel 4 - color - continious - 0 > 255 - 0 > 100%
channel 4 - i amber - intensity - 0 > 255 - 0 > 100%
My fixture:
channel 1 - cyan - variable - 0 > 255 - 0 > 100%
channel 2 - magenta - variable - 0 > 255 - 0 > 100%
channel 3 - yellow - variable - 0 > 255 - 0 > 100%
channel 4 - amber - variable - 0 > 255 - 0 > 100%
So now i can use "I Amber" and when i hit the clear button, the LED-bar turns of correctly but i no longer can use "Intensity" for the normal CMY.
How must the fixture look like, that i can use both and when clearing the programmer making the LED-bar go off...?
Cheers
Chris
