Open Timecode Toolbar (OT) Comment Macro Syntax
Heads Up!
I just got off the phone with HES and discovered that the 'OT' comment macro has some extra required syntax that's not in the current manual.
So, if you're using this macro (or want to) you'll need to append a console number to the end of the string.
The syntax is [ OThx ] where x is your console number.
OTh1 would open the timecode toolbar on Console number 1.
For What It's Worth,
Phil
