Hello All,
Sometimes when transitioning into and out of offset Hue Effects with LED fixtures while also changing the base Hue of the fixtures, some of the lights randomly flash white during the cue transitions. Also the problem is unpredictable. When transitioning between the cues, sometimes it occurs sometimes not, and it doesn't always effect the same instruments. I only use Hue Saturation for all of my color, never CMY. If I seperate the effect into one cue and the base hue change into a seperate cue, the problem goes away, but this process can be time consuming when programming a large show. Any help would be appreciated.
Thanks.
