Cuelist window only shows 4 cues
For some reason now when I load my show and open a cuelist (Open+Choose, double press Choose, etc) I can only see the first four cues of that cuelist. I can see all the cues in the playback bar, but no matter what I try I can only see 4 cues in the window!
With cuelists that have less than 4 cues, the window will show the one or two cues, followed by the 'End' row then enough blank rows below that to make four.
I've tried every window function (maximise/move window, Follow Cue, etc) and there is now way for me to see the entire cuelist of 85 cues.
I'm on IPC running the latest everything.
