iPC console running v3.0.1 (I think)
external usb keyboard and mouse connected
There has been frequent loss of input capability from the programming and playback surfaces that required a reboot to fix, and now this BSOD. Am I correct in assessing the this BSOD as a problem with the USB connections somewhere (see attachment). We're planning to open up the console and reseat all the cables. Also, we'll reload the software from .iso.
Anything else I should be looking for or try if the above does not work?
Thanks.
