Im finally making the switch to hog3 after years with hog2 and want to know if there is any way to make custom effects tables as you used to do with effect creator for hog 2?
Or is there a way of editing the exact values of a table direct in hog3. For example if i wanted to do an effect with a step curve from values 56 to 64 in the gobo channel (gobo effect).
Anthony
