Hello all i am currently running a Hog 3 with some Mac 2k's and Mac 2k Profiles. I have recently started having a problem with running my lights. I have programmed the lights into the cues and then for some reason now the console will not let me control them. Their adresses match the same as the patch and they are responding to where they were placed when i placed them in the cue but when i want them to go off they don't listen. The line on the output screen for these fixtures have turned black and will not let me change any attributes. Is there a button that i may have pushed to not let me control these lights? How can i gain control i would appreciate any response. Some of the lights will respond and change but some of the lights will not. Any ideas??
The Problem just recently started two days ago I was just creating a new show Everything was working fine and the lights were responding and then around 5am i guessed i pressed something but i can not remember what it is i pressed to have disabled these lighs. There has to be something simple that i acidentally typed in or pressed to cause this i just can't remember what that could be. Any Ideas? Two days ago these lights were running perfectly fine. I am running 2 Dp's, A WholeHog Server, Software ver 2.3.1 (b 1932), we have 9 Universes, Network is Hog3Embedded NIC.
