Hi All
I'm programming a H3PC system for am installation and have come a cross two things I need to be able to do but cant figure out how...
Firstly, is there a way to set a master or a VM to fade out when released by the clock? when released manually it works fine but not when same release macro is triggered by the clock
Secondly, I need the program to boot up in a custom view so the client can run some lists from the cuelist directory if they choose without needing to know 'how to use' the software
Cheers
Tim
