Showgun + H3
I used a bunch of showguns this weekend with an iPC (and will def be using them again) but wondered how I can program in and separate the led ring from the main light. I want to make a stack of programs for the regular light, then another stack for the led functions- I was able to do it, turning on led independent, but the LED ring's intensity would not fade down or up with the fader I assigned for the led functions.
Any idea how I'd program around that? I did it find on the GMA as you can patch the fixture and LEDs as different profiles.
