These might already be logged, but I wanted to add my comments.
I'm still running v3.0.3(2452)
Wholehog 3 console
I'm not sure what my specs are on my Vision machine, but I'll tell you it was custom built by the ESP Vision dudes, and all it runs is Vision.
I have two comments.
(1) Many times when I launch Vision and the connectivity driver starts, right before it says Output Active, it closes everything. It doesn't always do this, but it happens enough to be a bit of a headache. The connectivity driver is joining session and locating the server fine, its just that ever-so-often attempt that causes everything to close....much like a crash, only no error indicators.
(2) My Vision dongle is unlimited, and the rig I am currently working on uses 28 universes. I'm having no problem with fixtures patched into the first 24 universes, but anything in 25 through 32 is not working. My patching is good. If I clone the Universe to one of the working Vision Universes, it works fine.
