This is in 3.0.4 on an IPC, maybe on doing something wrong, but this seemed to work in hog 2, but maybe keystrokes are different in 3.
I made a cue 1 that has channel x up at a level, i then made a cue 2 that has channel y up at a level. I then typed Cue 1 Copy State Cue 3 Enter. I would expect for this to create a copy of cue 1 with only channels x up and not channels y, but the channels y track thru. Is this normal behaviour, the state command seems to be ignored.
Eric
