Hello,
I am running the following;
HOG3 PC v3.0.4 (b 2468); and
Capture Polar v2.1.7; on
Windows XP SP2
When loading these two applications, running on the same PC, the Hog3 Connectivity application does not load.
I have had the same issue for the past few months.
I have re-installed windows over the top (without formatting), removed the contents of the Hog3 & Capture folders and reinstalled, I had the same issue.
I have since then, formatted and reinstalled windows, and then reinstalled Hog3 & Capture, and had the same issue.
I have installed the Connectivity Application, and have the same issue.
I have turned on HOG3 Support in Capture Polar, and if it is any help, I run it with Polar graphics turned off (GL_ARB_color_buffer_float fails).
Any one had a similar issue, or know a fix ?
Regards
Mike!
