Edit Fixtures
I'm trying to label some gobo slots in the edit fixtures window.
There seems to be some inconsistency here, sometimes the edit fixtures window will open with a scroll bar at the bottom that allows me to scroll over to the gobo slots and label them up (i've done 3) and at other times there is no scroll bar and the last parameter in the spreadsheet is Max Speed in this case.
aha... what is happening is that if I select some different fixture types to edit in the sidebar, the scroll bar will randomly appear and disappear. the scroll bar is obviously not required for fixtures with few editable parameters but does not come on reliably for the ones that do...
i guess this is might be part of the general views problem? seems to be work-roundable..
