could we have the shortcut (fixture number)   back?
it used to (on hog II anyway) select fixtures from the unit entered to the end of the end of that type, ie studiocolor 1   would select all studiocolors.
It kind of still works, but now if the fixture numbers are non-contiguous the command line says it has selected the whole range, but the programmer only selects fixtures up to the break in the numbering......
it is a handy shortcut once you start using it.
well i liked it anyway.
