> Will the values show in the "DMX Output" window > even if a USB Widget is not connected or broken?
It depends on the software version. In newer software, the DMX window will only have data in it if there's a DP or Widget attached to that universe. I don't have my notes in front of me to remind me exactly when the behavior changed.
In 3.0.4 does the console only output DMX for addresses that are actually patched? So if address 4 in a given universe is not patched, it will not be outputted, this would be my assumption looking at the DMX window?
All the fixtures are patched, however DMX values are not displayed when the USB Widget is disconnected. What version do I need to install in order to see the DMX values independent of a connection to a Widget?
