Date:June 5 2009
Software Version and build number:3.0.0b2417
Number of displays:2
Connected USB Devices:0
Networked Devices:0
I have set up IM's on my faders of my Road Hog and switched the flash buttons for each of them to flash on and not off by holding open and pressing the choose button for the IM, going into options/master and set the flash to 100% instead of 0%. I close the window and push the flash key and it works so I move onto the next one. Once done the next one the previous one didn't work. This kept on going till I had all my flashes adjusted and then eventualy the last one set up wouldn't flash to 100%. They all would flast to 0% if I had the faders up. I restarted the console and then they all worked but as the console ran for a bit they all would eventually revert back to the whole flash to 0% but the settings would say that they are set to flash to 100%. Unfortunatly I can't upload the show file as I keep on getting an upload failed message so if you would like the show file please email me at continuum_lx@yahoo.ca and I'll gladly send you a copy.
