I'm designing and programming a dance show starting tomorrow on an iPC, and I have a thought that I wanted to run past everyone here.
We have four days of TECH, however more often than not, all of the 30+ dances in the show are rehearsed out of order. (Last year, I had to quickly adapt to using virtual masters with single cues and "release at end" enabled since I had no idea if I'd see a specific dance more than once). Obviously I don't want to have to do this again.
Most of the pieces will have a single "base look" with LTP / HTP elements layered on top, however there are a handful of dances with 10 or 20 cues in them. So, my thoughts are: Since I know the show order, my initial urge is to make blank "place holder" cues in a master cue list with each cue labeled as the base look for a given dance and just record them as needed during rehearsal (I'd use point cues for pieces with more than one cue).
My concern is that if the dances are rehearsed out of order, and I record out of order, I'll create all sorts of nasty tracking interactions. I know that I could just deselect "track forward" to make sure that all base cues for the dances have only hard values, but what are the implications of this (other than the obvious)? I usually only do this when I'm updating, so any insight would be appreciated. Thanks.
Jason
