A couple of things
Hi, a couple of questions
I was wanting to edit a group and pressed Group 121 Open. The group's contents came into the programmer. Is there a way to have these contents come into their own editor like when you open a cue. I was in a situation where i had other things in the programmer that I didn't want to add into the group.
I set a look on stage and then pressed Record Cue 1 Time 5/10. The command line turned blue which I think indicates that a command has occured? The cue was recorded but the time of the cue used the default time and not 5/10. Is this possible to do in one series of commands?
Eric
Parents
  • [quote=tedcook;38641]For clarification, recording groups always only looks at the selected fixtures, correct?
    That sounds correct to my knowledge. When parameters start getting attached, it becomes a palette. If you do record a group with a parameter in it, I dont think the parameter is recorded. However when using the group in programming, parameters can be quickly added within the same keystroke. as an example - I commonly use [Group] [X] [@] [X%].
    I also do not see the need to enhance the group creation/selection process any further.
    Regards,
Reply
    Regards,
Children
No Data
