Problems when closing fixture window
Hog III, current software, no accessories plugged in.
When closing the patch window, random fixtures (VL3000's, Studio Beams) will forget their default values, and pan/tilt to 0/0, and all other attributes go to 0. Not ALL fixtures do this, just certain ones.
Secondly, random dimmers will also flash. Can't tell if it is the same ones each time or different dimmers, but I will look closely.
Also, this does not happen EVERY time when exiting patch, but about 50% of the time. We can correct it by touching all parameters, then knocking it all out of the programmer. Also, this happens when parameters are modified in programmer AND when nothing is in the programmer. Only cues running are HTP handles for work and house lights.
Is this a known bug? I know in the past I have had to wait just a few seconds for the DP2000 to refresh right after patching, but this seems to be unrelated.
--Kirk Fitzgerald
Parents Reply Children
No Data
