IPC 3.04 Clone
Console IPC
Software 3.04
Connected Devices : USB Wing,analogue keyboard,2 x DP2000
i have a show created in 3.03 running in 3.04 OS on an IPC.
I'm having an issue where if i try to clone information within cuelists it is not showing on the output of the console but the values are in the cuelist.
This show has changed type from Mac 700's spots/wash to VL3500 spots/wash.
So if using the keystrokes
cue cue opens the cue,225+226 pig copy 231+232 enter update.I'm not touching the masking.
So if i then go cue cue the information is in the cue but not outputting when i try to play it back from the console.
I'm not in blind and i can see the values in the output view?
thanks C
