V3.0.5 - Fixture Problems
Hi everybody,
after updating my iPC to V3.0.5 i had some problems using VL2000 Spot (Standard 16bit) and HES StudioBeam. The StudioBeam fixture had 13 channels instead of 15 and VL2000 had 12 channels instead of 14.
After connecting the iPC with the VLs they startet rotating the color wheel and the shutter. The StudioBeams didn't do anything but pressing the Highlight-button resulted in a full tilit-move.
I decided to downgrade to V3.0.4 and after doing that i created a new show and patched the fixtures correctly and everything worked fine.
Where there any changes to the VL2000 and SB fixtures...?
Christian
