Error updating Hog3PC v3.0.5 on iPC (from fresh ISO 8.5.0 install)
Hi there,
I'm trying to update my iPC to the latest version.
I've downloaded XPe Image release 8.5.0 from your website, and just burned it into the console. All just fine at this point.
Then, I install Hog iPC Configuration Panel v3.0.5 (2482) without problems.
The error comes, when installing Hog 3PC v.3.0.5 (2482), it shows an error window:
Hog3PC 3.0.5.2482
Error writing to file: C:\Program Files\Flying Pig
Systems\Hog3PC\helptext\zh\sect_copying_moving_scenes.htm
Verify that you have access to that directory.
Retry - Cancel
If I press retry, the error repeats like in a buckle. If I press cancel, then undo all the installation, and comes again with v3.0.4.
There's any solution on this?
King regards,
Parents
  • Eric, that depends on the model of the motherboard in your iPC and how much memory is installed. I would try the install first before changing your bios settings.
    Raul, the factory optimized settings for the first, second, and third generation iPC models are located in this technical document:
    www.highend.com/support/downloads/dl/BIOSBattery_web.pdf
Reply
Children
No Data
