Hi all ,im wondering if in hog3 pc i can actually change the position timing in my pos. pallettes,like pos A to pos B in like 10 seconnds.i tried implementing delay,fades n click the fade change button but still wont work:confused:.i managed to do that using roadhog during a training session a few days ago..so i must have forgotten the 'finer' details or its not possible on a hog3 pc. Thanks all in advance
hi jon,thanks for the quick reply..ive tried ur method but stll wont work,ive try editing the palette n updating the paleete with TIME,still cant..im working with robe 575 spots n washs..i know i did it with roadhog..thanks again
Select the fixtures, choose the palette, add the time and then MERGE USE P and USE I. You have to have the position information in the programmer and merge both units....
Hopefully that will clear it up...or, as Eric described, use the editor and do it manually.
Are you trying to have this apply to the programmer when you change position pallets? If so you need to turn on Fade Changes in the programmer. When Fade changes is on this will allow timing to be applied in the programmer.
Also like the above post make sure you press Use P and Use T when you store the pallet.
ok guys thanks a lot,managed to do it..but my next problem is when i clear the programmer it takes the exact same time to go back to original position.is that normal or theres a way around it???And also Mike thanks alot,i was in ur last class in singapore..really really learned a lot:)
Turn off the Fade changes before you clear the programmer. With the fade changes on when you clear the programmer it will clear with the timing, turn off fade changes and it will clear as fast as it can.
