Tablet PC running H3PC networked
Hey all, I am looking at buying this tablet pc
www.circuitcity.com/applications/SearchTools/item-details.asp?EdpNo=4650044&CatId=219
What would I need to make this work as a remote focus device running my HOG IPC?
Parents
  • [quote=lightmike87;40018]So once you've networked the iPC to the laptop, do you just run the same show? and then that laptop becomes live?
    At startup/launcher window.
    Ensure that your client is running on the proper network adapter.
    Select "Settings"
    Turn off RUN SERVER
    Set client to be a console number that is different (usually "2" is fine)
    Rescan the network (if needed) and then log into the show that is already running.
    [quote=lightmike87;40018]With this said, If I were to leave the iPC in a booth and setup a tech table with a laptop and playback wing, networked to the console, I would be able to run cues?
    Yes.
    Hope this helps. :)
Reply
    Select "Settings"
    Turn off RUN SERVER
    Yes.
    Hope this helps. :)
Children
No Data
