ETC - Community
Site
Search
User
Site
Search
User
Control Consoles
Legacy Consoles
Legacy - Wholehog 3
proper method for upgrading software
More
Cancel
New
State
Not Answered
Date
ryanc - Former HES Forum Member
Date
Fri, Aug 7 2009 9:00 AM
Replies
Subscribers
6 subscribers
Views
Users
0 members are here
Hey all, just wondering if you guys/gals have any tips/tricks for upgrading an IPC from 2.6 - 3.0.2 ??
Which files do I go with first? Can I do it all from a USB stick?
0
jxgriffi - Former HES Forum Member
over 16 years ago
What console are you using?
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Cancel
0
over 16 years ago
HOG IPC
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Cancel
0
erock
over 16 years ago
Take a look at this:
www.flyingpig.com/support/BootableUSBFlashDrive.pdf
You will need to make a bootable USB drive per the instructions and then use the XPe image for the upgrade from www.flyingpig.com/phpscripts/hogipc/recovery.php which contains all of the files that you need, IPC config panel, Hog2PC and Hog3PC.
Eric
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Cancel
0
marty postma - Former HES Forum Member
over 16 years ago
Actually Hog iPCs must use a CD for re-imaging the HDD. Full install/restore via USB is only possible on RH & RHFB consoles.
Make sure you have backed up any showfiles externally as the entire HDD will be erased and then re-written with the new software.
You will need your console's serial number to access the download page.
Full burning instructions and install instructions are available on the website as well.
Hope this helps. :)
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Cancel
0
over 16 years ago
Thanks again Marty!
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Cancel
