You can use up to 3 widgets on an IPC. Hog II software is limited to 7 universes. You can use any combination of widgets and superwidgets to get to 7. There have been lots of improvements to the Hog software that make using the Ipc in H3 mode. One of those is to allow dp2000 and dp8000 to expend the number of universes beyond 7.
