can't get widget to install
Hi guys, i am using a samsung netbook and a 17" elo touchscreen running XP home for my HogPc setup but i can't get the widget to install, i have tried uninstalling and reinstalling hogpc including the older hog2pc release also many reboots but i still can't seem to get it to recognise the widget even if i point it to the windows/inf folder.
does anyone have any ideas?
  • XPsp3 is not a concern with newer versions of Hog3PC. It's only a problem if you had an old version of 3PC installed and then upgraded to sp3. If this is this first install of 3pc on this machine, then you don't need to worry about it.
    Try the powered hub.
    Also, if you have both 2PC and 3PC on the system, make sure you install 3PC *after* you installed 2PC. Also, it's best to have all wings and widgets unplugged when you install the software, then reboot after the install before you try and connect any widgets.
  • thanks eric i'll try that! i have another weird thing though, i use hog3pc and 2pc on my mac in bootcamp mode for patching/backup of my shows and i have just plugged the hog2 widget in that and its not working on that either! maybe its broken although it worked on the old machine before it died.....
  • [quote=jifop;41261]maybe its broken although it worked on the old machine before it died.....
    Try a new USB cable as well to rule it out.
  • :( well i have now tried using a powered usb hub and new cable and it still does exactly the same thing :( i guess its bricked which is rubbish as it worked fine on the old pc.
    plus i can't afford a new one at the moment :(
  • Send it in for repair then....much cheaper than buying new.
    Call support @ +1 (800) 890-8989
  • [quote=jifop;41259]It then says "cannot install the hardware"
    to produce a log of a failed device setup:
    [LIST=1]
    unplug your widget
    complete the resolution steps listed at: How to enable verbose logging on a Windows XP-based computer
    i suggest a LogLevel of 2000FFFF rather than the recommended 0000FFFF
    plug in your widget
    complete the Found New Hardware Wizard to the best of your ability
    set LogLevel back to 0
    find detailed information about this setup attempt at C:\Windows\setupapi.log
  • In case if you did not , try to disable , Norton ,firewal and all that virus protections crap. Anything that could stop software instalation.
  • to produce a log of a failed device setup:
    [LIST=1]
    unplug your widget
    plug in your widget
    tried this, once installing automatically and the secondtime pointing machine at windows/inf and this is what it said:
    [SetupAPI Log]
    OS Version = 5.1.2600 Service Pack 3
    Platform ID = 2 (NT)
    Service Pack = 3.0
    Suite = 0x0300
    Product Type = 1
    Architecture = x86
    [2009/09/21 07:59:44 880.3 Driver Install]
    #-019 Searching for hardware ID(s): usb\vid_04b0&pid_0001&rev_0000,usb\vid_04b0&pid_0001
    #-018 Searching for compatible ID(s): usb\class_ff&subclass_ff&prot_ff,usb\class_ff&subclass_ff,usb\class_ff
    #-198 Command line processed: C:\WINDOWS\system32\services.exe
    #-166 Device install function: DIF_SELECTBESTCOMPATDRV.
    #W059 Selecting best compatible driver failed. Error 0xe0000228: There are no compatible drivers for this device.
    #W157 Default installer failed. Error 0xe0000228: There are no compatible drivers for this device.
    [2009/09/21 07:59:46 3152.2]
    #-199 Executing "C:\WINDOWS\system32\rundll32.exe" with command line: rundll32.exe newdev.dll,ClientSideInstall \\.\pipe\PNP_Device_Install_Pipe_0.{D080C72C-753C-4D62-B726-0A3046AA0B6E}
    #I060 Set selected driver.
    [2009/09/21 08:02:53 880.3 Driver Install]
    @ 08:02:53.625 #V017 Enumerating files "C:\WINDOWS\inf".
    @ 08:02:53.640 #V392 Using INF cache "C:\WINDOWS\inf\INFCACHE.1".
    @ 08:02:53.640 #V073 Cache: Excluding INF "accessor.inf".
    @ 08:02:53.640 #V073 Cache: Excluding INF "agtinst.inf".
    @ 08:02:53.640 #V073 Cache: Excluding INF "apcompat.inf".
    @ 08:02:53.640 #V073 Cache: Excluding INF "appmig.inf".
    @ 08:02:53.640 #V073 Cache: Excluding INF "apps.inf".
    @ 08:02:53.640 #V073 Cache: Excluding INF "au.inf".
    @ 08:02:53.640 #V073 Cache: Excluding INF "axant5.inf".
    @ 08:02:53.640 #V073 Cache: Excluding INF "bda.inf".
    @ 08:02:53.640 #V073 Cache: Excluding INF "biosinfo.inf".
    @ 08:02:53.640 #V073 Cache: Excluding INF "branches.inf".
    @ 08:02:53.640 #V073 Cache: Excluding INF "camdsh20.inf".
    @ 08:02:53.640 #V073 Cache: Excluding INF "certclas.inf".
    @ 08:02:53.656 #V073 Cache: Excluding INF "communic.inf".
    @ 08:02:53.656 #V073 Cache: Excluding INF "comnt5.inf".
    @ 08:02:53.656 #V073 Cache: Excluding INF "corelist.inf".
    @ 08:02:53.656 #V073 Cache: Excluding INF "defltwk.inf".
    @ 08:02:53.656 #V073 Cache: Excluding INF "devxprop.inf".
    @ 08:02:53.656 #V073 Cache: Excluding INF "dfrg.inf".
    @ 08:02:53.656 #V073 Cache: Excluding INF "dimaps.inf".
    @ 08:02:53.656 #V073 Cache: Excluding INF "drm.inf".
    @ 08:02:53.656 #V073 Cache: Excluding INF "drvindex.inf".
    @ 08:02:53.656 #V073 Cache: Excluding INF "dshowext.inf".
    @ 08:02:53.656 #V073 Cache: Excluding INF "dtcnt5.inf".
    @ 08:02:53.656 #V073 Cache: Excluding INF "dwup.inf".
    @ 08:02:53.656 #V073 Cache: Excluding INF "fltmgr.inf".
    @ 08:02:53.656 #V073 Cache: Excluding INF "font.inf".
    @ 08:02:53.656 #V073 Cache: Excluding INF "fp40ext.inf".
    @ 08:02:53.656 #V073 Cache: Excluding INF "fsvgaadd.inf".
    @ 08:02:53.656 #V073 Cache: Excluding INF "fsvgadel.inf".
    @ 08:02:53.656 #V073 Cache: Excluding INF "fxsocm.inf".
    @ 08:02:53.656 #V073 Cache: Excluding INF "games.inf".
    @ 08:02:53.656 #V073 Cache: Excluding INF "icminst.inf".
    @ 08:02:53.656 #V073 Cache: Excluding INF "icwnt5.inf".
    @ 08:02:53.656 #V073 Cache: Excluding INF "ie.inf".
    @ 08:02:53.656 #V073 Cache: Excluding INF "ieaccess.inf".
    @ 08:02:53.656 #V073 Cache: Excluding INF "iereset.inf".
    @ 08:02:53.671 #V073 Cache: Excluding INF "igames.inf".
    @ 08:02:53.671 #V073 Cache: Excluding INF "iis.inf".
    @ 08:02:53.671 #V073 Cache: Excluding INF "ims.inf".
    @ 08:02:53.671 #V073 Cache: Excluding INF "intl.inf".
    @ 08:02:53.671 #V073 Cache: Excluding INF "koc.inf".
    @ 08:02:53.671 #V073 Cache: Excluding INF "ks.inf".
    @ 08:02:53.671 #V073 Cache: Excluding INF "kscaptur.inf".
    @ 08:02:53.671 #V073 Cache: Excluding INF "layout.inf".
    @ 08:02:53.671 #V073 Cache: Excluding INF "legcydrv.inf".
    @ 08:02:53.671 #V073 Cache: Excluding INF "mdac.inf".
    @ 08:02:53.671 #V073 Cache: Excluding INF "mdmgl001.inf".
    @ 08:02:53.671 #V073 Cache: Excluding INF "mdmgl002.inf".
    @ 08:02:53.671 #V073 Cache: Excluding INF "mdmgl003.inf".
    @ 08:02:53.671 #V073 Cache: Excluding INF "mdmgl004.inf".
    @ 08:02:53.671 #V073 Cache: Excluding INF "mdmgl005.inf".
    @ 08:02:53.671 #V073 Cache: Excluding INF "mdmgl006.inf".
    @ 08:02:53.671 #V073 Cache: Excluding INF "mdmgl007.inf".
    @ 08:02:53.671 #V073 Cache: Excluding INF "mdmgl008.inf".
    @ 08:02:53.671 #V073 Cache: Excluding INF "mdmgl009.inf".
    @ 08:02:53.671 #V073 Cache: Excluding INF "mdmgl010.inf".
    @ 08:02:53.687 #V073 Cache: Excluding INF "minioc.inf".
    @ 08:02:53.687 #V073 Cache: Excluding INF "mmopt.inf".
    @ 08:02:53.687 #V073 Cache: Excluding INF "moviemk.inf".
    @ 08:02:53.687 #V073 Cache: Excluding INF "mplayer2.inf".
    @ 08:02:53.687 #V073 Cache: Excluding INF "msinfo32.inf".
    @ 08:02:53.687 #V073 Cache: Excluding INF "msmsgs.inf".
    @ 08:02:53.687 #V073 Cache: Excluding INF "msnetmtg.inf".
    @ 08:02:53.687 #V073 Cache: Excluding INF "msnmsn.inf".
    @ 08:02:53.687 #V073 Cache: Excluding INF "msoe50.inf".
    @ 08:02:53.687 #V073 Cache: Excluding INF "mstask.inf".
    @ 08:02:53.687 #V073 Cache: Excluding INF "multimed.inf".
    @ 08:02:53.687 #V073 Cache: Excluding INF "multiprt.inf".
    @ 08:02:53.687 #V073 Cache: Excluding INF "mwremove.inf".
    @ 08:02:53.687 #V073 Cache: Excluding INF "mymusic.inf".
    @ 08:02:53.687 #V073 Cache: Excluding INF "netbeac.inf".
    @ 08:02:53.687 #V073 Cache: Excluding INF "netcis.inf".
    @ 08:02:53.687 #V073 Cache: Excluding INF "netclass.inf".
    @ 08:02:53.687 #V073 Cache: Excluding INF "netfw.inf".
    @ 08:02:53.687 #V073 Cache: Excluding INF "netias.inf".
    @ 08:02:53.703 #V073 Cache: Excluding INF "netiprip.inf".
    @ 08:02:53.703 #V073 Cache: Excluding INF "netlpd.inf".
    @ 08:02:53.703 #V073 Cache: Excluding INF "netoc.inf".
    @ 08:02:53.703 #V073 Cache: Excluding INF "netsnmp.inf".
    @ 08:02:53.703 #V073 Cache: Excluding INF "nettpsmp.inf".
    @ 08:02:53.703 #V073 Cache: Excluding INF "netupnp.inf".
    @ 08:02:53.703 #V073 Cache: Excluding INF "netupnph.inf".
    @ 08:02:53.703 #V073 Cache: Excluding INF "oeaccess.inf".
    @ 08:02:53.703 #V073 Cache: Excluding INF "oobe.inf".
    @ 08:02:53.703 #V073 Cache: Excluding INF "optional.inf".
    @ 08:02:53.703 #V073 Cache: Excluding INF "pchealth.inf".
    @ 08:02:53.703 #V073 Cache: Excluding INF "phdsext.inf".
    @ 08:02:53.703 #V073 Cache: Excluding INF "pinball.inf".
    @ 08:02:53.703 #V073 Cache: Excluding INF "pmxmcro.inf".
    @ 08:02:53.703 #V073 Cache: Excluding INF "printupg.inf".
    @ 08:02:53.703 #V073 Cache: Excluding INF "prtupg9x.inf".
    @ 08:02:53.703 #V073 Cache: Excluding INF "qmgr.inf".
    @ 08:02:53.703 #V073 Cache: Excluding INF "rootau.inf".
    @ 08:02:53.703 #V073 Cache: Excluding INF "sapi5.inf".
    @ 08:02:53.718 #V073 Cache: Excluding INF "sceregvl.inf".
    @ 08:02:53.718 #V073 Cache: Excluding INF "secdrv.inf".
    @ 08:02:53.718 #V073 Cache: Excluding INF "secrecs.inf".
    @ 08:02:53.718 #V073 Cache: Excluding INF "setupqry.inf".
    @ 08:02:53.718 #V073 Cache: Excluding INF "shell.inf".
    @ 08:02:53.718 #V073 Cache: Excluding INF "shl_img.inf".
    @ 08:02:53.718 #V073 Cache: Excluding INF "skins.inf".
    @ 08:02:53.718 #V073 Cache: Excluding INF "sr.inf".
    @ 08:02:53.718 #V073 Cache: Excluding INF "srchasst.inf".
    @ 08:02:53.718 #V073 Cache: Excluding INF "srusbusd.inf".
    @ 08:02:53.718 #V073 Cache: Excluding INF "sti.inf".
    @ 08:02:53.718 #V073 Cache: Excluding INF "svcpack.inf".
    @ 08:02:53.718 #V073 Cache: Excluding INF "swflash.inf".
    @ 08:02:53.718 #V073 Cache: Excluding INF "syscomp.inf".
    @ 08:02:53.718 #V073 Cache: Excluding INF "sysoc.inf".
    @ 08:02:53.718 #V073 Cache: Excluding INF "syssetup.inf".
    @ 08:02:53.718 #V073 Cache: Excluding INF "tshoot.inf".
    @ 08:02:53.718 #V073 Cache: Excluding INF "tsoc.inf".
    @ 08:02:53.718 #V073 Cache: Excluding INF "vgx.inf".
    @ 08:02:53.718 #V073 Cache: Excluding INF "wab50.inf".
    @ 08:02:53.718 #V073 Cache: Excluding INF "wbemoc.inf".
    @ 08:02:53.734 #V073 Cache: Excluding INF "wbemsnmp.inf".
    @ 08:02:53.734 #V073 Cache: Excluding INF "wmaccess.inf".
    @ 08:02:53.734 #V073 Cache: Excluding INF "wmdm.inf".
    @ 08:02:53.734 #V073 Cache: Excluding INF "wmfsdk.inf".
    @ 08:02:53.734 #V073 Cache: Excluding INF "wmp.inf".
    @ 08:02:53.734 #V073 Cache: Excluding INF "wmpocm.inf".
    @ 08:02:53.734 #V073 Cache: Excluding INF "wmtour.inf".
    @ 08:02:53.734 #V073 Cache: Excluding INF "wordpad.inf".
    @ 08:02:53.734 #V073 Cache: Excluding INF "wsh.inf".
    @ 08:02:53.734 #T075 Enumerating files: Directory pass completed.
    @ 08:02:53.734 #T076 Enumerating files: Cache pass completed.
    @ 08:02:53.734 #V017 Enumerating files "C:\PREINF\DRV0".
    @ 08:02:53.734 #V391 Creating empty INF cache.
    @ 08:02:53.734 #V017 Enumerating files "C:\PREINF\DRV1".
    @ 08:02:53.750 #V017 Enumerating files "C:\PREINF\DRV2".
    @ 08:02:53.750 #V391 Creating empty INF cache.
    @ 08:02:53.750 #T075 Enumerating files: Directory pass completed.
    @ 08:02:53.750 #T076 Enumerating files: Cache pass completed.
    @ 08:02:53.750 #V017 Enumerating files "C:\PREINF\DRV3".
    @ 08:02:53.750 #V017 Enumerating files "C:\PREINF\DRV4".
    @ 08:02:53.750 #V166 Device install function: DIF_SELECTBESTCOMPATDRV.
    @ 08:02:53.750 #V155 Executing default installer.
    @ 08:02:53.750 #W059 Selecting best compatible driver failed. Error 0xe0000228: There are no compatible drivers for this device.
    @ 08:02:53.750 #W157 Default installer failed. Error 0xe0000228: There are no compatible drivers for this device.
    [2009/09/21 08:02:55 988.2]
    #-199 Executing "C:\WINDOWS\system32\rundll32.exe" with command line: rundll32.exe newdev.dll,ClientSideInstall \\.\pipe\PNP_Device_Install_Pipe_0.{F0D84F36-8379-4969-AFD1-FAEFF6D8FEE1}
    @ 08:02:55.578 #I060 Set selected driver.
    @ 08:02:55.578 #V017 Enumerating files "C:\WINDOWS\inf".
    @ 08:02:55.578 #V392 Using INF cache "C:\WINDOWS\inf\INFCACHE.1".
    @ 08:02:55.593 #V073 Cache: Excluding INF "accessor.inf".
    @ 08:02:55.593 #V073 Cache: Excluding INF "agtinst.inf".
    @ 08:02:55.593 #V073 Cache: Excluding INF "apcompat.inf".
    @ 08:02:55.593 #V073 Cache: Excluding INF "appmig.inf".
    @ 08:02:55.593 #V073 Cache: Excluding INF "apps.inf".
    @ 08:02:55.593 #V073 Cache: Excluding INF "au.inf".
    @ 08:02:55.593 #V073 Cache: Excluding INF "axant5.inf".
    @ 08:02:55.593 #V073 Cache: Excluding INF "bda.inf".
    @ 08:02:55.593 #V073 Cache: Excluding INF "biosinfo.inf".
    @ 08:02:55.593 #V073 Cache: Excluding INF "branches.inf".
    @ 08:02:55.609 #V073 Cache: Excluding INF "camdsh20.inf".
    @ 08:02:55.609 #V073 Cache: Excluding INF "certclas.inf".
    @ 08:02:55.609 #V073 Cache: Excluding INF "communic.inf".
    @ 08:02:55.609 #V073 Cache: Excluding INF "comnt5.inf".
    @ 08:02:55.609 #V073 Cache: Excluding INF "corelist.inf".
    @ 08:02:55.609 #V073 Cache: Excluding INF "defltwk.inf".
    @ 08:02:55.609 #V073 Cache: Excluding INF "devxprop.inf".
    @ 08:02:55.609 #V073 Cache: Excluding INF "dfrg.inf".
    @ 08:02:55.609 #V073 Cache: Excluding INF "dimaps.inf".
    @ 08:02:55.609 #V073 Cache: Excluding INF "drm.inf".
    @ 08:02:55.609 #V073 Cache: Excluding INF "drvindex.inf".
    @ 08:02:55.609 #V073 Cache: Excluding INF "dshowext.inf".
    @ 08:02:55.609 #V073 Cache: Excluding INF "dtcnt5.inf".
    @ 08:02:55.625 #V073 Cache: Excluding INF "dwup.inf".
    @ 08:02:55.625 #V073 Cache: Excluding INF "fltmgr.inf".
    @ 08:02:55.625 #V073 Cache: Excluding INF "font.inf".
    @ 08:02:55.625 #V073 Cache: Excluding INF "fp40ext.inf".
    @ 08:02:55.625 #V073 Cache: Excluding INF "fsvgaadd.inf".
    @ 08:02:55.625 #V073 Cache: Excluding INF "fsvgadel.inf".
    @ 08:02:55.625 #V073 Cache: Excluding INF "fxsocm.inf".
    @ 08:02:55.625 #V073 Cache: Excluding INF "games.inf".
    @ 08:02:55.625 #V073 Cache: Excluding INF "icminst.inf".
    @ 08:02:55.625 #V073 Cache: Excluding INF "icwnt5.inf".
    @ 08:02:55.625 #V073 Cache: Excluding INF "ie.inf".
    @ 08:02:55.625 #V073 Cache: Excluding INF "ieaccess.inf".
    @ 08:02:55.625 #V073 Cache: Excluding INF "iereset.inf".
    @ 08:02:55.640 #V073 Cache: Excluding INF "igames.inf".
    @ 08:02:55.640 #V073 Cache: Excluding INF "iis.inf".
    @ 08:02:55.640 #V073 Cache: Excluding INF "ims.inf".
    @ 08:02:55.640 #V073 Cache: Excluding INF "intl.inf".
    @ 08:02:55.640 #V073 Cache: Excluding INF "koc.inf".
    @ 08:02:55.640 #V073 Cache: Excluding INF "ks.inf".
    @ 08:02:55.640 #V073 Cache: Excluding INF "kscaptur.inf".
    @ 08:02:55.640 #V073 Cache: Excluding INF "layout.inf".
    @ 08:02:55.640 #V073 Cache: Excluding INF "legcydrv.inf".
    @ 08:02:55.640 #V073 Cache: Excluding INF "mdac.inf".
    @ 08:02:55.640 #V073 Cache: Excluding INF "mdmgl001.inf".
    @ 08:02:55.640 #V073 Cache: Excluding INF "mdmgl002.inf".
    @ 08:02:55.656 #V073 Cache: Excluding INF "mdmgl003.inf".
    @ 08:02:55.656 #V073 Cache: Excluding INF "mdmgl004.inf".
    @ 08:02:55.656 #V073 Cache: Excluding INF "mdmgl005.inf".
    @ 08:02:55.656 #V073 Cache: Excluding INF "mdmgl006.inf".
    @ 08:02:55.656 #V073 Cache: Excluding INF "mdmgl007.inf".
    @ 08:02:55.656 #V073 Cache: Excluding INF "mdmgl008.inf".
    @ 08:02:55.656 #V073 Cache: Excluding INF "mdmgl009.inf".
    @ 08:02:55.656 #V073 Cache: Excluding INF "mdmgl010.inf".
    @ 08:02:55.656 #V073 Cache: Excluding INF "minioc.inf".
    @ 08:02:55.656 #V073 Cache: Excluding INF "mmopt.inf".
    @ 08:02:55.671 #V073 Cache: Excluding INF "moviemk.inf".
    @ 08:02:55.671 #V073 Cache: Excluding INF "mplayer2.inf".
    @ 08:02:55.671 #V073 Cache: Excluding INF "msinfo32.inf".
    @ 08:02:55.671 #V073 Cache: Excluding INF "msmsgs.inf".
    @ 08:02:55.671 #V073 Cache: Excluding INF "msnetmtg.inf".
    @ 08:02:55.671 #V073 Cache: Excluding INF "msnmsn.inf".
    @ 08:02:55.671 #V073 Cache: Excluding INF "msoe50.inf".
    @ 08:02:55.671 #V073 Cache: Excluding INF "mstask.inf".
    @ 08:02:55.671 #V073 Cache: Excluding INF "multimed.inf".
    @ 08:02:55.671 #V073 Cache: Excluding INF "multiprt.inf".
    @ 08:02:55.671 #V073 Cache: Excluding INF "mwremove.inf".
    @ 08:02:55.671 #V073 Cache: Excluding INF "mymusic.inf".
    @ 08:02:55.671 #V073 Cache: Excluding INF "netbeac.inf".
    @ 08:02:55.687 #V073 Cache: Excluding INF "netcis.inf".
    @ 08:02:55.687 #V073 Cache: Excluding INF "netclass.inf".
    @ 08:02:55.687 #V073 Cache: Excluding INF "netfw.inf".
    @ 08:02:55.687 #V073 Cache: Excluding INF "netias.inf".
    @ 08:02:55.687 #V073 Cache: Excluding INF "netiprip.inf".
    @ 08:02:55.687 #V073 Cache: Excluding INF "netlpd.inf".
    @ 08:02:55.687 #V073 Cache: Excluding INF "netoc.inf".
    @ 08:02:55.687 #V073 Cache: Excluding INF "netsnmp.inf".
    @ 08:02:55.687 #V073 Cache: Excluding INF "nettpsmp.inf".
    @ 08:02:55.687 #V073 Cache: Excluding INF "netupnp.inf".
    @ 08:02:55.703 #V073 Cache: Excluding INF "netupnph.inf".
    @ 08:02:55.703 #V073 Cache: Excluding INF "oeaccess.inf".
    @ 08:02:55.703 #V073 Cache: Excluding INF "oobe.inf".
    @ 08:02:55.703 #V073 Cache: Excluding INF "optional.inf".
    @ 08:02:55.703 #V073 Cache: Excluding INF "pchealth.inf".
    @ 08:02:55.703 #V073 Cache: Excluding INF "phdsext.inf".
    @ 08:02:55.703 #V073 Cache: Excluding INF "pinball.inf".
    @ 08:02:55.703 #V073 Cache: Excluding INF "pmxmcro.inf".
    @ 08:02:55.703 #V073 Cache: Excluding INF "printupg.inf".
    @ 08:02:55.703 #V073 Cache: Excluding INF "prtupg9x.inf".
    @ 08:02:55.703 #V073 Cache: Excluding INF "qmgr.inf".
    @ 08:02:55.718 #V073 Cache: Excluding INF "rootau.inf".
    @ 08:02:55.718 #V073 Cache: Excluding INF "sapi5.inf".
    @ 08:02:55.718 #V073 Cache: Excluding INF "sceregvl.inf".
    @ 08:02:55.718 #V073 Cache: Excluding INF "secdrv.inf".
    @ 08:02:55.718 #V073 Cache: Excluding INF "secrecs.inf".
    @ 08:02:55.718 #V073 Cache: Excluding INF "setupqry.inf".
    @ 08:02:55.718 #V073 Cache: Excluding INF "shell.inf".
    @ 08:02:55.718 #V073 Cache: Excluding INF "shl_img.inf".
    @ 08:02:55.718 #V073 Cache: Excluding INF "skins.inf".
    @ 08:02:55.718 #V073 Cache: Excluding INF "sr.inf".
    @ 08:02:55.718 #V073 Cache: Excluding INF "srchasst.inf".
    @ 08:02:55.718 #V073 Cache: Excluding INF "srusbusd.inf".
    @ 08:02:55.718 #V073 Cache: Excluding INF "sti.inf".
    @ 08:02:55.734 #V073 Cache: Excluding INF "svcpack.inf".
    @ 08:02:55.734 #V073 Cache: Excluding INF "swflash.inf".
    @ 08:02:55.734 #V073 Cache: Excluding INF "syscomp.inf".
    @ 08:02:55.734 #V073 Cache: Excluding INF "sysoc.inf".
    @ 08:02:55.734 #V073 Cache: Excluding INF "syssetup.inf".
    @ 08:02:55.734 #V073 Cache: Excluding INF "tshoot.inf".
    @ 08:02:55.734 #V073 Cache: Excluding INF "tsoc.inf".
    @ 08:02:55.734 #V073 Cache: Excluding INF "vgx.inf".
    @ 08:02:55.734 #V073 Cache: Excluding INF "wab50.inf".
    @ 08:02:55.734 #V073 Cache: Excluding INF "wbemoc.inf".
    @ 08:02:55.734 #V073 Cache: Excluding INF "wbemsnmp.inf".
    @ 08:02:55.734 #V073 Cache: Excluding INF "wmaccess.inf".
    @ 08:02:55.734 #V073 Cache: Excluding INF "wmdm.inf".
    @ 08:02:55.734 #V073 Cache: Excluding INF "wmfsdk.inf".
    @ 08:02:55.734 #V073 Cache: Excluding INF "wmp.inf".
    @ 08:02:55.734 #V073 Cache: Excluding INF "wmpocm.inf".
    @ 08:02:55.734 #V073 Cache: Excluding INF "wmtour.inf".
    @ 08:02:55.734 #V073 Cache: Excluding INF "wordpad.inf".
    @ 08:02:55.734 #V073 Cache: Excluding INF "wsh.inf".
    @ 08:02:55.734 #T075 Enumerating files: Directory pass completed.
    @ 08:02:55.734 #T076 Enumerating files: Cache pass completed.
    @ 08:02:55.750 #V017 Enumerating files "C:\PREINF\DRV0".
    @ 08:02:55.750 #V391 Creating empty INF cache.
    @ 08:02:55.750 #T075 Enumerating files: Directory pass completed.
    @ 08:02:55.750 #T076 Enumerating files: Cache pass completed.
    @ 08:02:55.750 #V017 Enumerating files "C:\PREINF\DRV1".
    @ 08:02:55.750 #V017 Enumerating files "C:\PREINF\DRV2".
    @ 08:02:55.750 #V017 Enumerating files "C:\PREINF\DRV3".
    @ 08:02:55.750 #V017 Enumerating files "C:\PREINF\DRV4".
    @ 08:02:55.765 #V166 Device install function: DIF_SELECTBESTCOMPATDRV.
    @ 08:02:55.765 #V155 Executing default installer.
    @ 08:02:55.765 #W059 Selecting best compatible driver failed. Error 0xe0000228: There are no compatible drivers for this device.
    @ 08:02:55.765 #W157 Default installer failed. Error 0xe0000228: There are no compatible drivers for this device.
    @ 08:03:02.796 #I060 Set selected driver.
    @ 08:03:02.812 #V017 Enumerating files "C:\WINDOWS\inf".
    @ 08:03:02.812 #V392 Using INF cache "C:\WINDOWS\inf\INFCACHE.1".
    @ 08:03:02.812 #V073 Cache: Excluding INF "accessor.inf".
    @ 08:03:02.812 #V073 Cache: Excluding INF "agtinst.inf".
    @ 08:03:02.812 #V073 Cache: Excluding INF "apcompat.inf".
    @ 08:03:02.812 #V073 Cache: Excluding INF "appmig.inf".
    @ 08:03:02.828 #V073 Cache: Excluding INF "apps.inf".
    @ 08:03:02.828 #V073 Cache: Excluding INF "au.inf".
    @ 08:03:02.828 #V073 Cache: Excluding INF "axant5.inf".
    @ 08:03:02.828 #V073 Cache: Excluding INF "bda.inf".
    @ 08:03:02.828 #V073 Cache: Excluding INF "biosinfo.inf".
    @ 08:03:02.828 #V073 Cache: Excluding INF "branches.inf".
    @ 08:03:02.828 #V073 Cache: Excluding INF "camdsh20.inf".
    @ 08:03:02.828 #V073 Cache: Excluding INF "certclas.inf".
    @ 08:03:02.828 #V073 Cache: Excluding INF "communic.inf".
    @ 08:03:02.828 #V073 Cache: Excluding INF "comnt5.inf".
    @ 08:03:02.828 #V073 Cache: Excluding INF "corelist.inf".
    @ 08:03:02.828 #V073 Cache: Excluding INF "defltwk.inf".
    @ 08:03:02.843 #V073 Cache: Excluding INF "devxprop.inf".
    @ 08:03:02.843 #V073 Cache: Excluding INF "dfrg.inf".
    @ 08:03:02.843 #V073 Cache: Excluding INF "dimaps.inf".
    @ 08:03:02.843 #V073 Cache: Excluding INF "drm.inf".
    @ 08:03:02.843 #V073 Cache: Excluding INF "drvindex.inf".
    @ 08:03:02.843 #V073 Cache: Excluding INF "dshowext.inf".
    @ 08:03:02.843 #V073 Cache: Excluding INF "dtcnt5.inf".
    @ 08:03:02.843 #V073 Cache: Excluding INF "dwup.inf".
    @ 08:03:02.843 #V073 Cache: Excluding INF "fltmgr.inf".
    @ 08:03:02.843 #V073 Cache: Excluding INF "font.inf".
    @ 08:03:02.843 #V073 Cache: Excluding INF "fp40ext.inf".
    @ 08:03:02.843 #V073 Cache: Excluding INF "fsvgaadd.inf".
    @ 08:03:02.859 #V073 Cache: Excluding INF "fsvgadel.inf".
    @ 08:03:02.859 #V073 Cache: Excluding INF "fxsocm.inf".
    @ 08:03:02.859 #V073 Cache: Excluding INF "games.inf".
    @ 08:03:02.859 #V073 Cache: Excluding INF "icminst.inf".
    @ 08:03:02.859 #V073 Cache: Excluding INF "icwnt5.inf".
    @ 08:03:02.859 #V073 Cache: Excluding INF "ie.inf".
    @ 08:03:02.859 #V073 Cache: Excluding INF "ieaccess.inf".
    @ 08:03:02.859 #V073 Cache: Excluding INF "iereset.inf".
    @ 08:03:02.859 #V073 Cache: Excluding INF "igames.inf".
    @ 08:03:02.875 #V073 Cache: Excluding INF "iis.inf".
    @ 08:03:02.875 #V073 Cache: Excluding INF "ims.inf".
    @ 08:03:02.875 #V073 Cache: Excluding INF "intl.inf".
    @ 08:03:02.875 #V073 Cache: Excluding INF "koc.inf".
    @ 08:03:02.875 #V073 Cache: Excluding INF "ks.inf".
    @ 08:03:02.875 #V073 Cache: Excluding INF "kscaptur.inf".
    @ 08:03:02.875 #V073 Cache: Excluding INF "layout.inf".
    @ 08:03:02.875 #V073 Cache: Excluding INF "legcydrv.inf".
    @ 08:03:02.875 #V073 Cache: Excluding INF "mdac.inf".
    @ 08:03:02.875 #V073 Cache: Excluding INF "mdmgl001.inf".
    @ 08:03:02.875 #V073 Cache: Excluding INF "mdmgl002.inf".
    @ 08:03:02.890 #V073 Cache: Excluding INF "mdmgl003.inf".
    @ 08:03:02.890 #V073 Cache: Excluding INF "mdmgl004.inf".
    @ 08:03:02.890 #V073 Cache: Excluding INF "mdmgl005.inf".
    @ 08:03:02.890 #V073 Cache: Excluding INF "mdmgl006.inf".
    @ 08:03:02.890 #V073 Cache: Excluding INF "mdmgl007.inf".
    @ 08:03:02.890 #V073 Cache: Excluding INF "mdmgl008.inf".
    @ 08:03:02.890 #V073 Cache: Excluding INF "mdmgl009.inf".
    @ 08:03:02.890 #V073 Cache: Excluding INF "mdmgl010.inf".
    @ 08:03:02.890 #V073 Cache: Excluding INF "minioc.inf".
    @ 08:03:02.890 #V073 Cache: Excluding INF "mmopt.inf".
    @ 08:03:02.906 #V073 Cache: Excluding INF "moviemk.inf".
    @ 08:03:02.906 #V073 Cache: Excluding INF "mplayer2.inf".
    @ 08:03:02.906 #V073 Cache: Excluding INF "msinfo32.inf".
    @ 08:03:02.906 #V073 Cache: Excluding INF "msmsgs.inf".
    @ 08:03:02.906 #V073 Cache: Excluding INF "msnetmtg.inf".
    @ 08:03:02.906 #V073 Cache: Excluding INF "msnmsn.inf".
    @ 08:03:02.906 #V073 Cache: Excluding INF "msoe50.inf".
    @ 08:03:02.906 #V073 Cache: Excluding INF "mstask.inf".
    @ 08:03:02.906 #V073 Cache: Excluding INF "multimed.inf".
    @ 08:03:02.921 #V073 Cache: Excluding INF "multiprt.inf".
    @ 08:03:02.921 #V073 Cache: Excluding INF "mwremove.inf".
    @ 08:03:02.921 #V073 Cache: Excluding INF "mymusic.inf".
    @ 08:03:02.921 #V073 Cache: Excluding INF "netbeac.inf".
    @ 08:03:02.921 #V073 Cache: Excluding INF "netcis.inf".
    @ 08:03:02.921 #V073 Cache: Excluding INF "netclass.inf".
    @ 08:03:02.921 #V073 Cache: Excluding INF "netfw.inf".
    @ 08:03:02.921 #V073 Cache: Excluding INF "netias.inf".
    @ 08:03:02.921 #V073 Cache: Excluding INF "netiprip.inf".
    @ 08:03:02.937 #V073 Cache: Excluding INF "netlpd.inf".
    @ 08:03:02.937 #V073 Cache: Excluding INF "netoc.inf".
    @ 08:03:02.937 #V073 Cache: Excluding INF "netsnmp.inf".
    @ 08:03:02.937 #V073 Cache: Excluding INF "nettpsmp.inf".
    @ 08:03:02.937 #V073 Cache: Excluding INF "netupnp.inf".
    @ 08:03:02.937 #V073 Cache: Excluding INF "netupnph.inf".
    @ 08:03:02.937 #V073 Cache: Excluding INF "oeaccess.inf".
    @ 08:03:02.937 #V073 Cache: Excluding INF "oobe.inf".
    @ 08:03:02.937 #V073 Cache: Excluding INF "optional.inf".
    @ 08:03:02.937 #V073 Cache: Excluding INF "pchealth.inf".
    @ 08:03:02.937 #V073 Cache: Excluding INF "phdsext.inf".
    @ 08:03:02.953 #V073 Cache: Excluding INF "pinball.inf".
    @ 08:03:02.953 #V073 Cache: Excluding INF "pmxmcro.inf".
    @ 08:03:02.953 #V073 Cache: Excluding INF "printupg.inf".
    @ 08:03:02.953 #V073 Cache: Excluding INF "prtupg9x.inf".
    @ 08:03:02.953 #V073 Cache: Excluding INF "qmgr.inf".
    @ 08:03:02.953 #V073 Cache: Excluding INF "rootau.inf".
    @ 08:03:02.953 #V073 Cache: Excluding INF "sapi5.inf".
    @ 08:03:02.953 #V073 Cache: Excluding INF "sceregvl.inf".
    @ 08:03:02.953 #V073 Cache: Excluding INF "secdrv.inf".
    @ 08:03:02.953 #V073 Cache: Excluding INF "secrecs.inf".
    @ 08:03:02.953 #V073 Cache: Excluding INF "setupqry.inf".
    @ 08:03:02.953 #V073 Cache: Excluding INF "shell.inf".
    @ 08:03:02.953 #V073 Cache: Excluding INF "shl_img.inf".
    @ 08:03:02.953 #V073 Cache: Excluding INF "skins.inf".
    @ 08:03:02.953 #V073 Cache: Excluding INF "sr.inf".
    @ 08:03:02.953 #V073 Cache: Excluding INF "srchasst.inf".
    @ 08:03:02.953 #V073 Cache: Excluding INF "srusbusd.inf".
    @ 08:03:02.953 #V073 Cache: Excluding INF "sti.inf".
    @ 08:03:02.953 #V073 Cache: Excluding INF "svcpack.inf".
    @ 08:03:02.953 #V073 Cache: Excluding INF "swflash.inf".
    @ 08:03:02.953 #V073 Cache: Excluding INF "syscomp.inf".
    @ 08:03:02.968 #V073 Cache: Excluding INF "sysoc.inf".
    @ 08:03:02.968 #V073 Cache: Excluding INF "syssetup.inf".
    @ 08:03:02.968 #V073 Cache: Excluding INF "tshoot.inf".
    @ 08:03:02.968 #V073 Cache: Excluding INF "tsoc.inf".
    @ 08:03:02.968 #V073 Cache: Excluding INF "vgx.inf".
    @ 08:03:02.968 #V073 Cache: Excluding INF "wab50.inf".
    @ 08:03:02.968 #V073 Cache: Excluding INF "wbemoc.inf".
    @ 08:03:02.968 #V073 Cache: Excluding INF "wbemsnmp.inf".
    @ 08:03:02.968 #V073 Cache: Excluding INF "wmaccess.inf".
    @ 08:03:02.968 #V073 Cache: Excluding INF "wmdm.inf".
    @ 08:03:02.968 #V073 Cache: Excluding INF "wmfsdk.inf".
    @ 08:03:02.968 #V073 Cache: Excluding INF "wmp.inf".
    @ 08:03:02.968 #V073 Cache: Excluding INF "wmpocm.inf".
    @ 08:03:02.968 #V073 Cache: Excluding INF "wmtour.inf".
    @ 08:03:02.968 #V073 Cache: Excluding INF "wordpad.inf".
    @ 08:03:02.968 #V073 Cache: Excluding INF "wsh.inf".
    @ 08:03:02.968 #T075 Enumerating files: Directory pass completed.
    @ 08:03:02.968 #T076 Enumerating files: Cache pass completed.
    @ 08:03:02.968 #V017 Enumerating files "C:\PREINF\DRV0".
    @ 08:03:02.984 #V391 Creating empty INF cache.
    @ 08:03:02.984 #T075 Enumerating files: Directory pass completed.
    @ 08:03:02.984 #T076 Enumerating files: Cache pass completed.
    @ 08:03:02.984 #V017 Enumerating files "C:\PREINF\DRV1".
    @ 08:03:02.984 #V017 Enumerating files "C:\PREINF\DRV2".
    @ 08:03:02.984 #V017 Enumerating files "C:\PREINF\DRV3".
    @ 08:03:02.984 #V017 Enumerating files "C:\PREINF\DRV4".
    @ 08:03:03.000 #V166 Device install function: DIF_SELECTBESTCOMPATDRV.
    @ 08:03:03.000 #V155 Executing default installer.
    @ 08:03:03.000 #W059 Selecting best compatible driver failed. Error 0xe0000228: There are no compatible drivers for this device.
    @ 08:03:03.000 #W157 Default installer failed. Error 0xe0000228: There are no compatible drivers for this device.
    @ 08:03:13.171 #I060 Set selected driver.
    @ 08:03:13.171 #V017 Enumerating files "C:\WINDOWS\inf".
    @ 08:03:13.187 #V392 Using INF cache "C:\WINDOWS\inf\INFCACHE.1".
    @ 08:03:13.187 #V073 Cache: Excluding INF "accessor.inf".
    @ 08:03:13.187 #V073 Cache: Excluding INF "agtinst.inf".
    @ 08:03:13.187 #V073 Cache: Excluding INF "apcompat.inf".
    @ 08:03:13.187 #V073 Cache: Excluding INF "appmig.inf".
    @ 08:03:13.187 #V073 Cache: Excluding INF "apps.inf".
    @ 08:03:13.187 #V073 Cache: Excluding INF "au.inf".
    @ 08:03:13.187 #V073 Cache: Excluding INF "axant5.inf".
    @ 08:03:13.187 #V073 Cache: Excluding INF "bda.inf".
    @ 08:03:13.187 #V073 Cache: Excluding INF "biosinfo.inf".
    @ 08:03:13.203 #V073 Cache: Excluding INF "branches.inf".
    @ 08:03:13.203 #V073 Cache: Excluding INF "camdsh20.inf".
    @ 08:03:13.203 #V073 Cache: Excluding INF "certclas.inf".
    @ 08:03:13.203 #V073 Cache: Excluding INF "communic.inf".
    @ 08:03:13.203 #V073 Cache: Excluding INF "comnt5.inf".
    @ 08:03:13.203 #V073 Cache: Excluding INF "corelist.inf".
    @ 08:03:13.203 #V073 Cache: Excluding INF "defltwk.inf".
    @ 08:03:13.203 #V073 Cache: Excluding INF "devxprop.inf".
    @ 08:03:13.203 #V073 Cache: Excluding INF "dfrg.inf".
    @ 08:03:13.203 #V073 Cache: Excluding INF "dimaps.inf".
    @ 08:03:13.203 #V073 Cache: Excluding INF "drm.inf".
    @ 08:03:13.218 #V073 Cache: Excluding INF "drvindex.inf".
    @ 08:03:13.218 #V073 Cache: Excluding INF "dshowext.inf".
    @ 08:03:13.218 #V073 Cache: Excluding INF "dtcnt5.inf".
    @ 08:03:13.218 #V073 Cache: Excluding INF "dwup.inf".
    @ 08:03:13.218 #V073 Cache: Excluding INF "fltmgr.inf".
    @ 08:03:13.218 #V073 Cache: Excluding INF "font.inf".
    @ 08:03:13.218 #V073 Cache: Excluding INF "fp40ext.inf".
    @ 08:03:13.218 #V073 Cache: Excluding INF "fsvgaadd.inf".
    @ 08:03:13.218 #V073 Cache: Excluding INF "fsvgadel.inf".
    @ 08:03:13.218 #V073 Cache: Excluding INF "fxsocm.inf".
    @ 08:03:13.218 #V073 Cache: Excluding INF "games.inf".
    @ 08:03:13.234 #V073 Cache: Excluding INF "icminst.inf".
    @ 08:03:13.234 #V073 Cache: Excluding INF "icwnt5.inf".
    @ 08:03:13.234 #V073 Cache: Excluding INF "ie.inf".
    @ 08:03:13.234 #V073 Cache: Excluding INF "ieaccess.inf".
    @ 08:03:13.234 #V073 Cache: Excluding INF "iereset.inf".
    @ 08:03:13.234 #V073 Cache: Excluding INF "igames.inf".
    @ 08:03:13.234 #V073 Cache: Excluding INF "iis.inf".
    @ 08:03:13.234 #V073 Cache: Excluding INF "ims.inf".
    @ 08:03:13.234 #V073 Cache: Excluding INF "intl.inf".
    @ 08:03:13.234 #V073 Cache: Excluding INF "koc.inf".
    @ 08:03:13.250 #V073 Cache: Excluding INF "ks.inf".
    @ 08:03:13.250 #V073 Cache: Excluding INF "kscaptur.inf".
    @ 08:03:13.250 #V073 Cache: Excluding INF "layout.inf".
    @ 08:03:13.250 #V073 Cache: Excluding INF "legcydrv.inf".
    @ 08:03:13.250 #V073 Cache: Excluding INF "mdac.inf".
    @ 08:03:13.250 #V073 Cache: Excluding INF "mdmgl001.inf".
    @ 08:03:13.250 #V073 Cache: Excluding INF "mdmgl002.inf".
    @ 08:03:13.250 #V073 Cache: Excluding INF "mdmgl003.inf".
    @ 08:03:13.250 #V073 Cache: Excluding INF "mdmgl004.inf".
    @ 08:03:13.250 #V073 Cache: Excluding INF "mdmgl005.inf".
    @ 08:03:13.265 #V073 Cache: Excluding INF "mdmgl006.inf".
    @ 08:03:13.265 #V073 Cache: Excluding INF "mdmgl007.inf".
    @ 08:03:13.265 #V073 Cache: Excluding INF "mdmgl008.inf".
    @ 08:03:13.265 #V073 Cache: Excluding INF "mdmgl009.inf".
    @ 08:03:13.265 #V073 Cache: Excluding INF "mdmgl010.inf".
    @ 08:03:13.265 #V073 Cache: Excluding INF "minioc.inf".
    @ 08:03:13.265 #V073 Cache: Excluding INF "mmopt.inf".
    @ 08:03:13.265 #V073 Cache: Excluding INF "moviemk.inf".
    @ 08:03:13.281 #V073 Cache: Excluding INF "mplayer2.inf".
    @ 08:03:13.281 #V073 Cache: Excluding INF "msinfo32.inf".
    @ 08:03:13.281 #V073 Cache: Excluding INF "msmsgs.inf".
    @ 08:03:13.281 #V073 Cache: Excluding INF "msnetmtg.inf".
    @ 08:03:13.281 #V073 Cache: Excluding INF "msnmsn.inf".
    @ 08:03:13.281 #V073 Cache: Excluding INF "msoe50.inf".
    @ 08:03:13.281 #V073 Cache: Excluding INF "mstask.inf".
    @ 08:03:13.281 #V073 Cache: Excluding INF "multimed.inf".
    @ 08:03:13.281 #V073 Cache: Excluding INF "multiprt.inf".
    @ 08:03:13.296 #V073 Cache: Excluding INF "mwremove.inf".
    @ 08:03:13.296 #V073 Cache: Excluding INF "mymusic.inf".
    @ 08:03:13.296 #V073 Cache: Excluding INF "netbeac.inf".
    @ 08:03:13.296 #V073 Cache: Excluding INF "netcis.inf".
    @ 08:03:13.296 #V073 Cache: Excluding INF "netclass.inf".
    @ 08:03:13.296 #V073 Cache: Excluding INF "netfw.inf".
    @ 08:03:13.296 #V073 Cache: Excluding INF "netias.inf".
    @ 08:03:13.296 #V073 Cache: Excluding INF "netiprip.inf".
    @ 08:03:13.296 #V073 Cache: Excluding INF "netlpd.inf".
    @ 08:03:13.312 #V073 Cache: Excluding INF "netoc.inf".
    @ 08:03:13.312 #V073 Cache: Excluding INF "netsnmp.inf".
    @ 08:03:13.312 #V073 Cache: Excluding INF "nettpsmp.inf".
    @ 08:03:13.312 #V073 Cache: Excluding INF "netupnp.inf".
    @ 08:03:13.312 #V073 Cache: Excluding INF "netupnph.inf".
    @ 08:03:13.312 #V073 Cache: Excluding INF "oeaccess.inf".
    @ 08:03:13.312 #V073 Cache: Excluding INF "oobe.inf".
    @ 08:03:13.312 #V073 Cache: Excluding INF "optional.inf".
    @ 08:03:13.312 #V073 Cache: Excluding INF "pchealth.inf".
    @ 08:03:13.328 #V073 Cache: Excluding INF "phdsext.inf".
    @ 08:03:13.328 #V073 Cache: Excluding INF "pinball.inf".
    @ 08:03:13.328 #V073 Cache: Excluding INF "pmxmcro.inf".
    @ 08:03:13.328 #V073 Cache: Excluding INF "printupg.inf".
    @ 08:03:13.328 #V073 Cache: Excluding INF "prtupg9x.inf".
    @ 08:03:13.328 #V073 Cache: Excluding INF "qmgr.inf".
    @ 08:03:13.328 #V073 Cache: Excluding INF "rootau.inf".
    @ 08:03:13.328 #V073 Cache: Excluding INF "sapi5.inf".
    @ 08:03:13.328 #V073 Cache: Excluding INF "sceregvl.inf".
    @ 08:03:13.328 #V073 Cache: Excluding INF "secdrv.inf".
    @ 08:03:13.328 #V073 Cache: Excluding INF "secrecs.inf".
    @ 08:03:13.328 #V073 Cache: Excluding INF "setupqry.inf".
    @ 08:03:13.328 #V073 Cache: Excluding INF "shell.inf".
    @ 08:03:13.328 #V073 Cache: Excluding INF "shl_img.inf".
    @ 08:03:13.328 #V073 Cache: Excluding INF "skins.inf".
    @ 08:03:13.328 #V073 Cache: Excluding INF "sr.inf".
    @ 08:03:13.328 #V073 Cache: Excluding INF "srchasst.inf".
    @ 08:03:13.328 #V073 Cache: Excluding INF "srusbusd.inf".
    @ 08:03:13.328 #V073 Cache: Excluding INF "sti.inf".
    @ 08:03:13.328 #V073 Cache: Excluding INF "svcpack.inf".
    @ 08:03:13.343 #V073 Cache: Excluding INF "swflash.inf".
    @ 08:03:13.343 #V073 Cache: Excluding INF "syscomp.inf".
    @ 08:03:13.343 #V073 Cache: Excluding INF "sysoc.inf".
    @ 08:03:13.343 #V073 Cache: Excluding INF "syssetup.inf".
    @ 08:03:13.343 #V073 Cache: Excluding INF "tshoot.inf".
    @ 08:03:13.343 #V073 Cache: Excluding INF "tsoc.inf".
    @ 08:03:13.343 #V073 Cache: Excluding INF "vgx.inf".
    @ 08:03:13.343 #V073 Cache: Excluding INF "wab50.inf".
    @ 08:03:13.343 #V073 Cache: Excluding INF "wbemoc.inf".
    @ 08:03:13.343 #V073 Cache: Excluding INF "wbemsnmp.inf".
    @ 08:03:13.343 #V073 Cache: Excluding INF "wmaccess.inf".
    @ 08:03:13.343 #V073 Cache: Excluding INF "wmdm.inf".
    @ 08:03:13.343 #V073 Cache: Excluding INF "wmfsdk.inf".
    @ 08:03:13.343 #V073 Cache: Excluding INF "wmp.inf".
    @ 08:03:13.343 #V073 Cache: Excluding INF "wmpocm.inf".
    @ 08:03:13.343 #V073 Cache: Excluding INF "wmtour.inf".
    @ 08:03:13.343 #V073 Cache: Excluding INF "wordpad.inf".
    @ 08:03:13.343 #V073 Cache: Excluding INF "wsh.inf".
    @ 08:03:13.359 #T075 Enumerating files: Directory pass completed.
    @ 08:03:13.359 #T076 Enumerating files: Cache pass completed.
    @ 08:03:13.359 #V017 Enumerating files "C:\PREINF\DRV0".
    @ 08:03:13.359 #V391 Creating empty INF cache.
    @ 08:03:13.359 #V017 Enumerating files "C:\PREINF\DRV1".
    @ 08:03:13.359 #V017 Enumerating files "C:\PREINF\DRV2".
    @ 08:03:13.359 #V017 Enumerating files "C:\PREINF\DRV3".
    @ 08:03:13.375 #T076 Enumerating files: Cache pass completed.
    @ 08:03:13.375 #V017 Enumerating files "C:\PREINF\DRV4".
    @ 08:03:13.375 #V391 Creating empty INF cache.
    @ 08:03:13.375 #T075 Enumerating files: Directory pass completed.
    @ 08:03:13.375 #V017 Enumerating files "c:\windows\inf".
    @ 08:03:13.375 #V392 Using INF cache "c:\windows\inf\INFCACHE.1".
    @ 08:03:13.375 #V073 Cache: Excluding INF "accessor.inf".
    @ 08:03:13.375 #V073 Cache: Excluding INF "agtinst.inf".
    @ 08:03:13.375 #V073 Cache: Excluding INF "apcompat.inf".
    @ 08:03:13.375 #V073 Cache: Excluding INF "appmig.inf".
    @ 08:03:13.375 #V073 Cache: Excluding INF "apps.inf".
    @ 08:03:13.375 #V073 Cache: Excluding INF "au.inf".
    @ 08:03:13.375 #V073 Cache: Excluding INF "axant5.inf".
    @ 08:03:13.390 #V073 Cache: Excluding INF "bda.inf".
    @ 08:03:13.390 #V073 Cache: Excluding INF "biosinfo.inf".
    @ 08:03:13.390 #V073 Cache: Excluding INF "branches.inf".
    @ 08:03:13.390 #V073 Cache: Excluding INF "camdsh20.inf".
    @ 08:03:13.390 #V073 Cache: Excluding INF "certclas.inf".
    @ 08:03:13.390 #V073 Cache: Excluding INF "communic.inf".
    @ 08:03:13.390 #V073 Cache: Excluding INF "comnt5.inf".
    @ 08:03:13.390 #V073 Cache: Excluding INF "corelist.inf".
    @ 08:03:13.390 #V073 Cache: Excluding INF "defltwk.inf".
    @ 08:03:13.390 #V073 Cache: Excluding INF "devxprop.inf".
    @ 08:03:13.390 #V073 Cache: Excluding INF "dfrg.inf".
    @ 08:03:13.390 #V073 Cache: Excluding INF "dimaps.inf".
    @ 08:03:13.390 #V073 Cache: Excluding INF "drm.inf".
    @ 08:03:13.390 #V073 Cache: Excluding INF "drvindex.inf".
    @ 08:03:13.390 #V073 Cache: Excluding INF "dshowext.inf".
    @ 08:03:13.390 #V073 Cache: Excluding INF "dtcnt5.inf".
    @ 08:03:13.390 #V073 Cache: Excluding INF "dwup.inf".
    @ 08:03:13.390 #V073 Cache: Excluding INF "fltmgr.inf".
    @ 08:03:13.406 #V073 Cache: Excluding INF "font.inf".
    @ 08:03:13.406 #V073 Cache: Excluding INF "fp40ext.inf".
    @ 08:03:13.406 #V073 Cache: Excluding INF "fsvgaadd.inf".
    @ 08:03:13.406 #V073 Cache: Excluding INF "fsvgadel.inf".
    @ 08:03:13.406 #V073 Cache: Excluding INF "fxsocm.inf".
    @ 08:03:13.406 #V073 Cache: Excluding INF "games.inf".
    @ 08:03:13.406 #V073 Cache: Excluding INF "icminst.inf".
    @ 08:03:13.406 #V073 Cache: Excluding INF "icwnt5.inf".
    @ 08:03:13.406 #V073 Cache: Excluding INF "ie.inf".
    @ 08:03:13.406 #V073 Cache: Excluding INF "ieaccess.inf".
    @ 08:03:13.406 #V073 Cache: Excluding INF "iereset.inf".
    @ 08:03:13.406 #V073 Cache: Excluding INF "igames.inf".
    @ 08:03:13.406 #V073 Cache: Excluding INF "iis.inf".
    @ 08:03:13.406 #V073 Cache: Excluding INF "ims.inf".
    @ 08:03:13.406 #V073 Cache: Excluding INF "intl.inf".
    @ 08:03:13.406 #V073 Cache: Excluding INF "koc.inf".
    @ 08:03:13.406 #V073 Cache: Excluding INF "ks.inf".
    @ 08:03:13.406 #V073 Cache: Excluding INF "kscaptur.inf".
    @ 08:03:13.421 #V073 Cache: Excluding INF "layout.inf".
    @ 08:03:13.421 #V073 Cache: Excluding INF "legcydrv.inf".
    @ 08:03:13.421 #V073 Cache: Excluding INF "mdac.inf".
    @ 08:03:13.421 #V073 Cache: Excluding INF "mdmgl001.inf".
    @ 08:03:13.421 #V073 Cache: Excluding INF "mdmgl002.inf".
    @ 08:03:13.421 #V073 Cache: Excluding INF "mdmgl003.inf".
    @ 08:03:13.421 #V073 Cache: Excluding INF "mdmgl004.inf".
    @ 08:03:13.421 #V073 Cache: Excluding INF "mdmgl005.inf".
    @ 08:03:13.421 #V073 Cache: Excluding INF "mdmgl006.inf".
    @ 08:03:13.421 #V073 Cache: Excluding INF "mdmgl007.inf".
    @ 08:03:13.421 #V073 Cache: Excluding INF "mdmgl008.inf".
    @ 08:03:13.421 #V073 Cache: Excluding INF "mdmgl009.inf".
    @ 08:03:13.421 #V073 Cache: Excluding INF "mdmgl010.inf".
    @ 08:03:13.421 #V073 Cache: Excluding INF "minioc.inf".
    @ 08:03:13.421 #V073 Cache: Excluding INF "mmopt.inf".
    @ 08:03:13.421 #V073 Cache: Excluding INF "moviemk.inf".
    @ 08:03:13.437 #V073 Cache: Excluding INF "mplayer2.inf".
    @ 08:03:13.437 #V073 Cache: Excluding INF "msinfo32.inf".
    @ 08:03:13.437 #V073 Cache: Excluding INF "msmsgs.inf".
    @ 08:03:13.437 #V073 Cache: Excluding INF "msnetmtg.inf".
    @ 08:03:13.437 #V073 Cache: Excluding INF "msnmsn.inf".
    @ 08:03:13.437 #V073 Cache: Excluding INF "msoe50.inf".
    @ 08:03:13.437 #V073 Cache: Excluding INF "mstask.inf".
    @ 08:03:13.437 #V073 Cache: Excluding INF "multimed.inf".
    @ 08:03:13.437 #V073 Cache: Excluding INF "multiprt.inf".
    @ 08:03:13.437 #V073 Cache: Excluding INF "mwremove.inf".
    @ 08:03:13.437 #V073 Cache: Excluding INF "mymusic.inf".
    @ 08:03:13.437 #V073 Cache: Excluding INF "netbeac.inf".
    @ 08:03:13.437 #V073 Cache: Excluding INF "netcis.inf".
    @ 08:03:13.437 #V073 Cache: Excluding INF "netclass.inf".
    @ 08:03:13.437 #V073 Cache: Excluding INF "netfw.inf".
    @ 08:03:13.437 #V073 Cache: Excluding INF "netias.inf".
    @ 08:03:13.437 #V073 Cache: Excluding INF "netiprip.inf".
    @ 08:03:13.453 #V073 Cache: Excluding INF "netlpd.inf".
    @ 08:03:13.453 #V073 Cache: Excluding INF "netoc.inf".
    @ 08:03:13.453 #V073 Cache: Excluding INF "netsnmp.inf".
    @ 08:03:13.453 #V073 Cache: Excluding INF "nettpsmp.inf".
    @ 08:03:13.453 #V073 Cache: Excluding INF "netupnp.inf".
    @ 08:03:13.453 #V073 Cache: Excluding INF "netupnph.inf".
    @ 08:03:13.453 #V073 Cache: Excluding INF "oeaccess.inf".
    @ 08:03:13.453 #V073 Cache: Excluding INF "oobe.inf".
    @ 08:03:13.453 #V073 Cache: Excluding INF "optional.inf".
    @ 08:03:13.453 #V073 Cache: Excluding INF "pchealth.inf".
    @ 08:03:13.453 #V073 Cache: Excluding INF "phdsext.inf".
    @ 08:03:13.453 #V073 Cache: Excluding INF "pinball.inf".
    @ 08:03:13.453 #V073 Cache: Excluding INF "pmxmcro.inf".
    @ 08:03:13.453 #V073 Cache: Excluding INF "printupg.inf".
    @ 08:03:13.453 #V073 Cache: Excluding INF "prtupg9x.inf".
    @ 08:03:13.453 #V073 Cache: Excluding INF "qmgr.inf".
    @ 08:03:13.453 #V073 Cache: Excluding INF "rootau.inf".
    @ 08:03:13.468 #V073 Cache: Excluding INF "sapi5.inf".
    @ 08:03:13.468 #V073 Cache: Excluding INF "sceregvl.inf".
    @ 08:03:13.468 #V073 Cache: Excluding INF "secdrv.inf".
    @ 08:03:13.468 #V073 Cache: Excluding INF "secrecs.inf".
    @ 08:03:13.468 #V073 Cache: Excluding INF "setupqry.inf".
    @ 08:03:13.468 #V073 Cache: Excluding INF "shell.inf".
    @ 08:03:13.468 #V073 Cache: Excluding INF "shl_img.inf".
    @ 08:03:13.468 #V073 Cache: Excluding INF "skins.inf".
    @ 08:03:13.468 #V073 Cache: Excluding INF "sr.inf".
    @ 08:03:13.468 #V073 Cache: Excluding INF "srchasst.inf".
    @ 08:03:13.468 #V073 Cache: Excluding INF "srusbusd.inf".
    @ 08:03:13.468 #V073 Cache: Excluding INF "sti.inf".
    @ 08:03:13.468 #V073 Cache: Excluding INF "svcpack.inf".
    @ 08:03:13.468 #V073 Cache: Excluding INF "swflash.inf".
    @ 08:03:13.468 #V073 Cache: Excluding INF "syscomp.inf".
    @ 08:03:13.468 #V073 Cache: Excluding INF "sysoc.inf".
    @ 08:03:13.468 #V073 Cache: Excluding INF "syssetup.inf".
    @ 08:03:13.484 #V073 Cache: Excluding INF "tshoot.inf".
    @ 08:03:13.484 #V073 Cache: Excluding INF "tsoc.inf".
    @ 08:03:13.484 #V073 Cache: Excluding INF "vgx.inf".
    @ 08:03:13.484 #V073 Cache: Excluding INF "wab50.inf".
    @ 08:03:13.484 #V073 Cache: Excluding INF "wbemoc.inf".
    @ 08:03:13.484 #V073 Cache: Excluding INF "wbemsnmp.inf".
    @ 08:03:13.484 #V073 Cache: Excluding INF "wmaccess.inf".
    @ 08:03:13.484 #V073 Cache: Excluding INF "wmdm.inf".
    @ 08:03:13.484 #V073 Cache: Excluding INF "wmfsdk.inf".
    @ 08:03:13.484 #V073 Cache: Excluding INF "wmp.inf".
    @ 08:03:13.484 #V073 Cache: Excluding INF "wmpocm.inf".
    @ 08:03:13.484 #V073 Cache: Excluding INF "wmtour.inf".
    @ 08:03:13.484 #V073 Cache: Excluding INF "wordpad.inf".
    @ 08:03:13.484 #V073 Cache: Excluding INF "wsh.inf".
    @ 08:03:13.484 #T075 Enumerating files: Directory pass completed.
    @ 08:03:13.484 #T076 Enumerating files: Cache pass completed.
    @ 08:03:13.500 #V166 Device install function: DIF_SELECTBESTCOMPATDRV.
    @ 08:03:13.500 #V155 Executing default installer.
    @ 08:03:13.500 #W059 Selecting best compatible driver failed. Error 0xe0000228: There are no compatible drivers for this device.
    @ 08:03:13.500 #W157 Default installer failed. Error 0xe0000228: There are no compatible drivers for this device.
  • [quote=jifop;41284]#-019 Searching for hardware ID(s): usb\vid_04b0&pid_0001
    the correct descriptor for a dmx widget is VID_0CB0&PID_0001; yours being different points to EEPROM corruption.
    fortunately, dmx widgets don't store much in their cypress boot EEPROM's: a (corrupted) usb descriptor, a serial number, the 3PC "proof-of-purchase", etcetera, so the damage may be minimal, and it might be worked around.
    all the code for dmx slot generation, blinking the LED's and such is not stored in EEPROM, but downloaded to RAM; installing this code to your widget is the sole purpose of the first (loading) driver.
    to get the first driver to deposit this code onto your widget, you'll need to edit fps_dmx.inf: replace all occurrences of VID_0CB0&PID_0001 with VID_04B0&PID_0001 (this is roughly equivalent to changing a _lib manufacturer = line)
    leave all VID_0CB0&PID_0002's as they are; once your VID_04b0&PID_001 usb controller gets its code, it will correctly ReNumerate as a VID_0CB0&PID_0002 dmx widget and the second (friendly) driver will be matched to fps_dmx.inf based on this descriptor, which is hard-coded in the payload transferred by the (loader) driver.
    no promises, but if it works, remember to make the same change on your other machine, and back-up the .inf which will be overwritten with every 2PC or 3PC install.
  • you sir are a fricking legend! all is good in hogpc land!
    thanks a million
