IPC Graphic card died - now HOG3PC crashes
Hi!
Not too long ago the graphic card (ATI Radeon 9250 PCI 128MB VRAM) died with crashing the HOG IPC on startup. I removed the card and replaced it with similar card (ATI Radeon 9250 128MB VRAM PCI) but a different brand.
After I tried to do a full system restore with the XPe 8.5.0 image.
Install worked fine but it won't start the config menu and crashes the HOG3PC startup. Pics attached...
Possible issues: old IPC with a new XPe 8.5.0?
Where can I download an older image like 8.2.2 which should work...
Thanks...
81.21.114.51/IPC_1.JPG
81.21.114.51/IPC_2.JPG
