I am having some trouble with effect fade and effect delay times.
1. I am not able to change the fade and delay time for all functions at once (effect engine, column "ALL") or even for a subset (All Intensity, All Color, All Beam, All Position). Changing just on function (like PAN or Cyan) works like it should.
2. I am not able to use the command line for changing effect times. EFFECT TIME 5 gives a red command line an does not work.
System : HOG3PC V3.1.0
Any ideas?
Best,
 Chris
