multiple list commands
Is there a way to select a number of cuelists at the same time and select a different setting for these, for example HTP option? I tried selecting them in the spreadsheet but that did not work.
Greetings Joris
  • Unfortunately no there is no way to adjust mutliple list options at once. However if they are all on the same page, you can open the options window on one and then change the choose key for each list while the options window is open and make the changes rather quickly.
