Backup tracking
With the recent possibility of the m audio uno in the recent software release does this open any options to be able to do a show backup/tracking via a pc during the show??
Mike
  • It should allow you to do the same kind of MSC setup that you can do with the other Hog consoles, this would be using the master console to send MSC commands to a slave console that has it's own means of creating DMX and then using an A/B switch to switch over in the event that the master console fails. This is not over the network and tracks playback only, not programming, so the two consoles would need to have identical show files. It does work quite well.
    Eric
