iPC clock bug?
I'm not sure if this is a bug, nor when it started, but think that it only started after v2.4. I always do full install of 'iPC image' from CD, whenever a new iso file is available.
Both our iPC's, which have different version motherboards, but same version of software, lose 1 hour on the clock every time we power up.
ie If clock is correct, power down, power up, clock will lose 1 hour.
If clock is 1 (or 2 or 3...) hour(s) behind, when we start up it will lose 1 more hour.
In Control panel, time zone is set to GMT +8 for Singapore.
Both iPC's are not connected to network, and are running different shows.
Regards,
Craig
Proud owner of 2 iPC, 6 Hog3PC with 8 mini p/b wings, 5 mini program wings, and . . . a brand new Full Boar with 2 RH wings!
:hogsign: :hogsign: :hogsign:
