I have a simple chase in cuelist and need to change the fixture numbers. Is that posable? Right now I'm using desk channel 1-6 but need to switch to 7-12. It's a 10 step chase. Thanks in advance
The easiest way to do this is to open each cue and then copy the information from 1-6 to 7-12. The steps would be; Cue 1 open, select 1-6 copy 7-12 enter, then reselect 1-6 and knock them out of the cue. Now only 7-12 should be in the cue with the copied info from 1-6, then press update to put the cue back. Now repeat for the rest of the cues.
