ETC - Community
Site
Search
User
Site
Search
User
Control Consoles
Legacy Consoles
Legacy - Wholehog 3
RHFB Desklight
More
Cancel
New
State
Not Answered
Date
doller - Former HES Forum Member
Date
Tue, Nov 24 2009 5:16 AM
Replies
Subscribers
6 subscribers
Views
Users
0 members are here
RHFB Desklight
When i start the full Boar ,the Desklights are out.
When i press setup and make the desklevel at 0 and the worklight on full ,is the right desklamp on??
give it a trick for lamps on??:dunno:
greeds
0
sfeerpeer - Former HES Forum Member
over 16 years ago
desklights are coupled, both should work, or non.
so this is indeed strange. did you swap the desklamp, and did the error also swap?
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Cancel
0
over 16 years ago
I have swap from left to right and it is the same the left is on and the right out.
it is possiblle cables in the console are not conected?
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Cancel
0
over 16 years ago
might be, just unscrew frontcover and push connectors on print/check connection on neutrik-plug.
But the worklight should be the light in front-bottom??
So it looks like maybe internal wires are crossed?
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Cancel
0
over 16 years ago
the worklight are ok the two blue and one white.
thx i check this after the show..
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Cancel
0
over 16 years ago
and, found the problem?
Cancel
Vote Up
0
Vote Down
Sign in to reply
Verify Answer
Cancel
