i have a new Road Hog v3.1 and have everything set up no problem... what i need to know is how to create a pallet with my cues, or one touch programs that i have created so it is easy to use for the people that have to use my board when i cant do it...
You don't create palettes for that. You create your standard cue lists.
To trigger them, open the cuelist window (List Open). Be sure to turn off GUARD (upper left corner of the window). Then, when you touch the cuelist button, it will trigger. Another thing to remember is that the buttons REMEMBER what the fader value was at when it was recorded. If the fader was down, then it remembers that. If you don't see intensity, you probably need to move it to a master, raise the fader to full and delete it from the master (Choose Delete). Then the fader value will be remembered as Full.
With this option, you need to setup a way to RELEASE the lists.
Take a look at this thread to get some different ideas.
