Running 3.1.1 on a WholeHog 3 and (1) DP2000.
During Progamming the last few days I noticed the Follow Trigger was causing the previous cue (0 second fade) to show the "R" in the Wait column.  The cue executed in 0 seconds but the "R" ran and then I got my follow.  When I removed the follow, no more "R" on the previous cue.
I temorarily fixd it by using a Wait trigger instead.
I am heading back shortly and will test it on a new cuelist.
I will also check to make sure there are no fades or delays in the previous cue.
Will post my results.
