Connect problem Hog 3PC & Wysiwyg
Hello Everybody,
I can´t connect the hog 3PC 3.1.1 with Wysiwyg R23. The Wysiwyg is instaled in a BootCamp partition of a Mac Pro with Windows 7 64 bits and the Hog PC in a laptop with windows vista 32 bits. I' ve tried a lot off settings (connecting with crossover cable and with a ethernet switch, using DHCP and static IP, changing the port, changing the user number, etc...) and the result is the same: When I start Wysiwyg, the Wholehog DP Connectivity shows "Wholehog network found" and "Initialising network OK" for a few moment but after shows status: Connecting and Info: Scanning port 6600 / Checking software version.
The network works fine with other applications. e.g. the wysiwyg connects with grandMA onPC without problems.
I have instaled ESET Smart Security in both computers but I turn it off to try the connection.
Can anyone help me, I must make a complicated programming in January, and I want to work a lot with wysiwyg.
