Copy and Paste
Hi, I have two network shares set up to transfer backup shows files too, what I normally do is create a backup in the Shows folder on the console's (IPC) hard drive. I then copy this file and navigate to one of the network shares and paste it, to be able to paste it to the other network share, I have to go back to the shows folder and recopy it, if I go directly to the other share from the first one, the paste option is greyed out.
Is it possible to have the console allow you to paste this file as much as you want similar to the way a windows computer does, the item remains on the clipboard until something else replaces it.
Eric
