Holiday Surprise!!
[CENTER]:hogsign: UNDOCUMENTED FEATURE :hogsign:
[/CENTER]
Starting with version 3.1.0 and greater if you click on an aggregate bar in any spreadsheet, it will select all fixtures of the same type in that column. This is an extremely useful method to select and edit fixtures by type.
Examples of use:
In the patch window: click the aggregate bar for a type above "num" and then press set to quickly renumber the fixture numbers.
In the programmer or cue editor: click the aggregate bar for a type above a parameter and then press set to quickly edit the parameter for all fixtures of that type in the cue or programmer (remember there must be a value to edit)
Enjoy and Happy Holidays!
