Is it possible to remove a value from several cues with one simple command?
Now I´m working around the problem with dimmers by merging the wanted dimmers at 0% level to all necessary cues.
Example:
select channel 1 thru 6 -> at 0% -> merge cue 1 thru 12
This sets channels 1 > 6 at 0% to cues 1 > 12.
Basically works fine but when working with other fixtures I would prefer to remove unnecessary info from cues.
Would help in reprogramming show lists when I have tracking info only in necessary cues.
-j-
