It appears ELO discontinued the 1725L. Is the 1729L compatible? I'm looking for some accutouch 17" displays that will work with both XPe and WH3. I'm aware of the list on page 68 of the WH3 manual, so no need to reference it :rtfm:
Elo seems to change model numbers very often, but usually the items are pretty much the same. The monitors listed in the manual are the ones that we have tested and confirmed work. In theory as long as Elo continues to use the same drivers for their monitors you can use their "new" model numbers. Look on their website for compatibility information to see if the new 1729L is comparable to the 1725L.
Again we can not "support" the newest models until we test with them, so your experience could vary.
