Color Scheme Problem
Hey everyone I am running a Whole Hog 3 with the sw version 2.3.1. I have a problem with the color scheme for all of my output screens. All of my other shows are in default color except this one show. I have a black and white background screen instead of the normal grey and white colors. How do i change the background color i know its something very easy but i can't seem to figure it out.
Richard
  • Richard
    Here is how you can change the color scheme
    Setup
    Perferences
    Color Scheme - set to normal
  • Another way to change quickly is to use the "Import Preferences" function.
    Keep in mind, this will change ALL preferences! But, if you have what you like on a regular show, choose EXPORT PREFERENCES and save it on the hard drive. Then, in the other shows, just import the preference file and it will be how you like it.
    I have a few preference files depending on what I'm working on.
    DL2/Axon - changes wheelsets (everything else how I like it...)
    Showpix - changes wheelsets (everything else how I like it...)
    Program - Color - Normal, some basic timings, and basic wheelsets
    Operate - Color - DARK, some basic timings and wheelsets
    Light - Color Normal, gamma changed, timing and wheelsets normal
    Dark - Color Dark, gamma changed, timing and wheelsets normal
    Hope it helps.
