Hello to All - I am a new forum user, hoping I am posting in the correct place.
I have a RoadHog running v2.5 software and installed a ShowLED controller/curtain. I am having a problem with the curtain control and have tried replacing the controller without success. Looking for other ideas as to my problem.
When changing parameters to set-up a look before turning on the intensity, the curtain will flash brightly once whenever the Pattern Type (Hard Chase to Soft Chase) parameter is changed. Only happens with this one parameter of the curtain and only going from Hard to Soft or 0% to 100%. This happens in cues or if I grab the fixture in the programmer and and just change that one parameter with the wheel.
Anyone run into this before? Could an software or library update to the console possibly help - such as moving to the v3 software?
Adam
