Wysiwyg connectivity
Hi everybody!
I cannot connect to wysiwyg.
Both my Hog Ipc and Hog3pc run on the same computer where wyg is installed.
I tried to downgrade to hog3pc 3.0.5 and I was able to connect to wyg as always. I tried to install all the software from 3.1 to the latest drop and if I do so the problem comes back. the connectivity driver finds the show but it stays idle all the time (waiting to connect). I'm running wyg and Hog3pc on a macbook pro under bootcamp. I reckon this is not the problem for I couldn't connect to wyg when using 3.0.5 either. Is anyone else seeing this?
