Hi gents, I have 1 Dp2k with 3.0.5 and hog pc with 3.1.0 and than i will update the dp . the dp is on dhcp. In network window cannot find the dp to update??
Make sure Hog3PC is setup to use the proper network adapter in network tab of the control panel and also check that the adapter you have selected in Hog3PC is also set to serve DHCP (unless a router on the network is already acting as the DHCP server).
