I just had a desk crash and not reboot. have a pc here with 3pc on it and a back up of show and a super widget. i cannot get the pc to talk to the widget. any help. show in 30 mins. thanks
Can you give more detailed info on what is happening. And also call the after hours on high end. They are usually good at calling back within 10 minutes in my experience.
The internal DP8000 is a virtual DMX engine that runs on your PC that allows you to connect single or superwidgets to get DMX output. On 3PC you are limited to 8 universes (2 superwidgets) worth of physical dmx output.
To configure the widgets to work with your internal dmx processor 8000 you will need to patch at least one fixture to get the dmx processor 8000 to the point where is says "Outputs Active" in the network window. From there you will want to click the settings button for the dmx processor 8000 in the network window and navigate to the dmx widgets outputs tab. The rest should be pretty easy to figure o
