I am trying to add my Mac running HogPC via Parallels 5 to my Hog3 so i can do a network show backup (don't worry its all disconnected before I run the show) I am having trouble with the network settings and was wondering if anyone has got it too work.
Hi, I am trying to connect my Macbook to another console via Airport. I use bridged network and I can connect to the network show. But after launching the playback and desktop process nothing else is happening.
The start-window just freezes. As standalone editor everything is working fine.
[QUOTE=TiaMarzett;49985]Everything seems to be connected, but I did notice that if I got onto Windows then Local Area Connection in Network Settings, it says in the support tab that the address type has been manually configured.
That is the program changing the ip settings so the computer can connect to the dp2000. It will go back to automatic ip settings when you close the program.
