It seems that the 4th encoder wheel isn't responding on my Road Hog. I actually thought something was wrong with the fixture libraries at first, then I realized nothing responds to that wheel. Has anyone else run into this? Looking for a quick fix or work-around.
You can use the console test application (available from the startup window) to determine if the hardware is working properly. If will show you exactly what the four encoders are doing.
As a short-term work-around, you can use the wheelset editor to re-map the 4th wheel functions to other wheels on different encoder pages.
