Hello All,
I'm a month and a half deep in my new Roadhog Wholehog V3.1.1
I've read the manual over and over but what am I missing?
I can't seam to get the Tap Sync function working.
When I do attempt this the chase goes with the tap but once i stop it goes back to it's set bpm. I hold down the choose key of the master then tap away at the Master Go. Simple enough but no go.
What gives?
-From the manual
Adjusting Chase Rate with Tap Sync
A cuelist chase can be manually sync'ed to a beat, such as a piece of music, using Tap
Sync. Once sync'ed Wholehog OS maintains the chase rate until a new one is assigned.
To adjust the rate of a chase using Tap Sync, hold down the Choose key of the master
the chase is attached to, while pressing the master's Go key repeatedly to the required
beat. Wholehog OS will learn the speed of the chase from you, in a minimum of two
beats; after this, you can release the Choose key.
Note that you can only use Tap Sync with chases loaded onto physical masters, not
virtual ones.
